How do we view what users are connected to our VPN tunnels? We currently have 2 different locations set up for VPN and would like to be able to check and see who has been connected, how long, etc but I am unsure of how to do this.
Solved! Go to Solution.
If you click on the drop-down filter, you can select a "client type" of "client-vpn" (you can also just type this in).
The ones with a round world symbol like below are AnyConnect users. There is a different icon for those people using the Microsoft client VPN.
They show up under Network Wide -> Clients with some information. But it takes some time. It's far away from being real-time.
This is showing items connected in to various WAPs or Switches at least from what I can tell... but I want to see users that are connected into our actual VPN tunnel.
You can filter on VPN users.
This is exactly what I was looking for! Thanks!
