How to create meraki dashboard for 1 organization with 4 region
YogeshK
Just browsing
I Have client organization, spread in 4 different region  so I looking help to create dashboard with multiple region (APAC,EU,NA,SA) . As the process showing with mail id while creating dashboard we have to select region. what is process/ steps to create dashboard single organization with 4 region.
Brash
You can logically group networks with network tags. They're somewhat useful by themselves but are especially person when played with the API
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Organization_Menu...
GreenMan
Meraki Alumni (Retired)
A single Dashboard Organization can only be hosted in one region.   What are you looking to achieve or gain from having different regions?
Remember that the Dashboard is only for management - your user traffic does not flow through it, so it isn't essential, for most customers, that the hosting is local to the users.
YogeshK
Just browsing
Thank you !
If we can create a dashboard in single region and general settings (time/snmp/maintenance window) can add under each network that also solving my purpose but is there any way to group networks per region for easy management. - top Hierarchy is organization then Networks created in each region may add some label - North America/EMEA/ASPAC so ops management perspective easy search network.
Brash
Brash
As @GreenMan said, there's no need to create separate organisations.
The dashboard is for management only and any country specific regulatory settings are applied on a per network basis.
https://documentation.meraki.com/MR/Radio_Settings/MR_Regulatory_Domains#Regulatory_Domain_Setting_f...
