Firmware upgrades for Meraki Monitor
Emlu
Hello.
Does anyone know, when new IOS XE versions will be avalible to update to?
I would like to try to use Ckiud Monitoring - Image Upgrade to upgrade to  17.9.6 since it's the new star release, but it's not yet available in the Meraki Portal.
It is usually announced when a new firmware is released.
However, I believe predictions are something internal to them.
https://community.meraki.com/t5/Firmware-Upgrades-Feed/bg-p/firmwareupgrades
michalc
Hi There,
We don't have an estimated arrival time for version 17.9.6 at the moment. Thank you for your understanding and patience.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
Emlu
Hi.
Thank you for the response
Just for feedback, i think it would be nice if at least the star releases was available with this service
