Export AP Locations
KCraig87
Export AP Locations
Anyone know if it possible to Export Access Points and have its location information contained within the report? Lat/Longitute or Address  information would be sufficient.
So far I have exported from "Wireless -> Access Points" and "Organization -> Inventory". However neither report contains the location of the AP.
You would need to write a script and use the Dashboard API.
The function you need is:
HTTP REQUEST
GET /networks/[networkId]/devices
PARAMETERS
    None
SAMPLE REQUEST
curl -L -H 'X-Cisco-Meraki-API-Key: <key>' -X GET -H 'Content-Type: application/json' 'https://dashboard.meraki.com/api/v0/networks/[networkId]/devices'
SAMPLE RESPONSE
Successful HTTP Status: 200
    "name":"My AP",
    "lat":37.4180951010362,
    "lng":-122.098531723022,
    "serial":"Q2XX-XXXX-XXXX",
    "mac":"00:11:22:33:44:55:66",
    "model":"MR34",
    "address":"1600 Pennsylvania Ave",
    "lanIp":"1.2.3.4"
    "tags":" recently-added ",
    "networkId":"N_1234",
    "beaconIdParams": {
      "uuid": "00000000-0000-0000-0000-000000000000",
      "major": 5,
      "minor": 3,
KCraig87
Nevermind, figured it out. Native XML report provide Lat/Long information. But turning on the API and getting the Google Earth KML file fit my needs perfectly.
Noriko
Just browsing
Related to this case, please tell me how to get AP MAP of dashboard with a device name of PC user by using API.
