From what I've been able to find so far, removing a device from a Network does not default or change any of it's configs. So if we have an AP broadcasting SSIDs, it's still going to be broadcasting those SSID's even after we remove from the Network. Which is what we are trying to avoid. Additionally there's not going to be anyone onsite to hard reset in this scenario. The only time this will come up is if a customer is no longer going to be using the service. Often times they leave the equipment plugged in, so we need a way to remove from network and erase configs remotely.
Is there a way to erase configs via the Dashboard or API call? I'm not finding a way to do that just yet.
If there isn't a way to reset remotely via dashboard or API the only other thing I can think of is to set up a "Default" Network that doesn't broadcast any SSIDs, then move it to that network. Do you have any other ideas on how this can be accomplished? Essentially the goal is to remove from network and have configs erased so that clients can't see the SSID's broadcasting any longer.
thanks!
