Device Status Icon
AaronH
Device Status Icon
A simple question, from a noob. In the dashboard, I have some clients that I know are connected via my AP, yet their "status" on the dashboard shows a green port, not a wifi icon. Why would the status show a wired connection when these devices are only capable of wifi connections? Is there a way to change that icon to reflect the true connectivity? Meraki AP is hardwired to Meraki switch port 8.
Nick
I presume you are seeing this with in the Network Wide clients section?
Are your AP's Meraki? If not then technically to the switch or MX they are "hardwired"
Nick
BrechtSchamp
Does it show those clients when you change the drop-down in clients list to "only access point clients"?
Is all the Meraki kit in the same network in the dashboard?
AaronH
I realized shortly after I posted that all those clients are through my old Apple Express that is hardwired to Port 1 on the switch. So, you are spot on. Thank you!
