Dashboard Settings and Meraki Vision
DanielBHSNIT
Does Vision use the same settings as the dashboard; i.e., if dashboard is set to log off after so many minutes of inactivity, does that carry over to Vision or does Vision have its' own?
1 Reply 1
Jinbe
Org idle timeout is ignored if viewing live footage via the video wall and there is no idle timeout in the full-screen view. Otherwise, the user will follow the idle timeout defined for the Organization.
More information on Vision Portal Behavior and idle timeout can be found here: https://documentation.meraki.com/MV/Viewing_Video/Vision_Portal%3A_Introduction
