Custom Report
Youssef
Custom Report
Is there a way to create a custom report that shows detail data (# of clients, # of unique clients, data usage and client per day) for all networks. Thanks
3 REPLIES 3
jdsilva
Hey @Youssef. You can do this under Organization > Summary reports. Select the scope of the report in the Network(s) dropdown, and then choose what you want to see under Customize report. You can set up email schedules for it once you have the data included you want.
Thank you for the quick response. The report generated in that manner gives me the total figures but not detailed per network/device. I have to select each network individually then generate the report. I have 27 networks and i was looking for a report that generate all the data at once instead of selecting one at a time. Thanks again
jdsilva
Sorry @Youssef , that doesn't exist 😞
