Connected VPN Clients Not Visible
TheLittlestMofo
Connected VPN clients are showing in Event Logs but not under Network-Wide > Clients, getting the below error when trying to view a connected client from the logs:
Sorry, we couldn't find that client. Please go back and try again.
Is there an issue at the moment that hasn't been reported?
1 Reply 1
Ehteshamul
Did you tried searching by Mac address of those device if not getting in Network-wide>client>vpn client.you just need to search it by filtering. Hopefully you will get that.If not then support is solution.
