Configuration change alerts not using email
MW0013
We get plenty of emails... I didn't see an option under the Syslog entries that shows anything about configuration change alerts. Does Meraki offer a way to send notices of configuration changes or alerts through Syslog or another means that doesn't include email? I want it to be an automatic push configuration, not a pull configuration from another system through an API or something, if possible.
2 REPLIES 2
CN
Meraki Alumni (Retired)
Sounds like webhooks would fit the bill of what you're looking for.
You could use WebHooks as @CN and combine it with a commercial service like Pager Duty.  Then you could develop a more formal workflow for processing alerts of different types.
https://developer.cisco.com/meraki/build/meraki-alerts-with-pagerduty/
