Search instead for
Combined Network vs SM
I have been using Meraki for SM up till now for MDM of various ipads, etc.  I just bought Meraki hardware and am a little confused as it wont let me mix SM and meraki hardware, is that correcT?
I have SM clients that will be used in the network I just made of meraki hardware (switch, appliance, ap) and I would like to put them all together, this is not possible?
Accepted Solutions
Re: Combined Network vs SM
That is correct. You can not combine other network types with Systems Manager.
5 REPLIES 5
Thanks, so the best practice is just to create the hardware networks and their corresponding SM networks or do you typically create your hardware networks and dump all SM into a single SM network?
I typically create a combined network per physical site for all the Cisco Meraki physical hardware.
I typically create one Systems Manager network for the entire organisation.
Thanks, I assume there would be no issue creating multiple SM networks though correct?  I have multiple separate divisions within the company that i would like to keep completely separate.
I've never done it, but I don't see any issue with that.
You could also use tags for this purpose (creating a tag per division) and assign those tags to the devices.
