Co-Term Licensing
Naresh_Pattu
Co-Term Licensing
Currently i have created one network and added 9300-M switches with "Advanced" License, now i want create one more network which will have MS220 switches with "Enterprise" license.
I want to clarify, whether the MS220 switches requires "Enterprise" License or "Advanced" license, since all the devices will be in the same organization
Ryan_Miles
Meraki Employee All-Star
The MS220 only supports Ent licensing. You should be able to have both in the same org without issue.
Naresh_Pattu
Thanks 👍
MartinLL
You can have both in the same org.
Also, i would suggest that you take a look at the subscription licensing model. It might suit your org well.
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Subscription_Licensing_Over...
MLL
Naresh_Pattu
Thanks 👍
