Cisco Services down?
rhbirkelund
Anyone else not able to reach Meraki Dashboard or even Webex? Cisco.com won't load either.
CN Dashboard responds and is available, though.
7 Replies 7
GiacomoS
Hey @rhbirkelund ,
I'm UK based and everything is loading fine for me.
Have you tried some traceroutes & nslookups to pinpoint what the traffic is stopping?
Many thanks!
Giac
Please keep in mind that what I post here is my personal knowledge and opinion. Don't take anything I say for the Holy Grail, but try and see!
Appreciate who helps and be respectful of every opinion and every solution offered.
Share the love, especially the Meraki one!
Rumour has it, it might be an ISP issue.
Github is unavailble, as well as https://status.aws.amazon.com/
And it seems to be back again.
Funny though, because all customers on TDC ISP in Denmark seemed to be affected, but when doing traceroutes, it looked like the issue was further out, than TDC network.
DarrenOC
Fine here. Been using Webex all morning and CCWs loading fine
Azure had a major outage around that time period.  Perhaps Azure is used for part of the operation.
https://www.zdnet.com/article/global-azure-outage-knocked-out-virtual-machines-other-vm-dependent-se...
Inderdeep
@rhbirkelund : Azure down , These days a lot of platform down like Facebook & companies and now Azure 🙂
Regards/Inder
www.thenetworkdna.com
Rumour has it that our ISP had an issue with the transatlantic line to New York…
