Gotcha. As you've seen if you just leave a value out when using API it should ignore/not change the current value.
You'd probably need to use Runner in Postman and use a source spreadsheet with a column of all the switch serials. I've not tried this specific scenario, but I assume it should work. If you haven't used Runner you'll need to read up on it and do some testing to get the basics down.
