Does anyone have any information regarding Meraki's ability to automatically remediate faults using AI or machine learning? I'm led to believe it doesn't have this ability at the moment but is there a timeline for this being a feature? ANy info gratefully received as the good old world webby is scarce on info on this topic as far as Meraki is concerned. Thanks
I don't think there is anything like that right now. I use the Dashboard API to check the items that compliance is being maintained. You could codify your configuration and then just run a script every few minutes.
Hey @ChrisJones2015. Meraki doesn't discuss roadmap items here on the community, so I doubt very much you're going to get the answer you're looking for. I'd suggest reaching out to your reps and ask them.
I wasn't looking for any specific faults or resolutions but something similar to the Cisco Automated Fault Management system, so something that will learn to recognise potential issues and work to resolve them in the background.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da752a4f7d053","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da752a4f7d053_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da752a4f7d053_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6da752a4f7d053_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6da7529d710515","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
