Hi this might be a noob issue but I'm unable to find any application information in the dashboard. Any help is appreciated.
Can you scroll right, perhaps by using the right cursor key?
Have you tried a different browser?
Appreciate the response. Same results with Firefox or Chrome.
Did it used to work, and only just broke recently (like today)?
This is my lab. I setup it up a month ago.. all worked fined. I just re-setup everything today and discovered the issue. Is there a setting to hide application traffic?
I bet something is wrong with the shard that you are on. Try opening a case with support.
Looks like a UI issue to me. Have you tried creating a new network and seeing if the Pie chart appears?
Give it some time, it will show up.
