Search instead for
Aggregation of bandwidth usage statistics on MX
Hello guys. I've a question about the bandwidth statistics on MX.
I would like to make a report about last 6 months of wan network usage.
What I see is that if I zoom out the peaks and spikes are "aggregated" or are lowered down to a different speed. See attached image. Is that a bug or what?
Another question.. is there a way to get the statistics not "aggregated" ?
5 REPLIES 5
Re: Aggregation of bandwidth usage statistics on MX
no and no.
its hard to save and display 30months view of every second.
most vendors display only average of 5 minute interval. if you look at longer period the interval may not be 5 min but 15 or something.
hey,
I've not asked for 30 months of single second peak.
6 months of 5 minutes average would be more than enough.
Any workaround with 3rd part software? (snmp or api) ?
did not try it but netflow could be a solution
As @ww says either Netflow or SNMP monitoring might do it.  The SNMP monitoring tools I know do the same thing though.
Thanks guys!
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
