vMX azure route problem
Abechara
hello,
i have  an environnent auto vpn between meraki mx, i added vMX on Azure cloud i followed the steps here
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Microsoft_Azure
i configured all, vMX(HUB) can ping inside azure subnets but the users behind another Mx (HUB) cannot reach the Azure subnets, can reach only internal vMX ip 192.168.128.1/24
azure vnet is 10.1.0.0/20
azure subnets 10.1.1.0/24
                         10.1.2.0/24
i created route table as mentioned in meraki documentation but still same problem cannot reach azure behind mx and i am sure it is a routing problem
Do the Azure routes appear in the Meraki routing table?
If not, make sure you add them under Site-to-Site VPN, under VPN Settings, Local Networks.
8 Replies 8
Ensure that the Network Security Groups and any Azure firewalls are configured to allow traffic between the subnets and from the on-premises network.
Abechara
firewall allow all and nsg also
GreenMan
Meraki Alumni (Retired)
A bit of guesswork to help further without Dashboard visibility - did you raise a case with Meraki Support?
Abechara
no i am trying the solve it i didnt raise it with meraki support as it may be from azure
Abechara
no and that is the problem how can they appear? we cannot add them manually in site to site
Abechara
what i did i used the same subnet in azure in the internal ip of vMX and i did static route so it overlaps but it worked
Hal9K
Are your Azure route Tables for the Azure VNETs/subnets pointing to the Meraki virtual appliance with the routes beyond the Meraki vmX ?
