We did follow the guide as per your link. but somehow rather its cant work.
below is our lambda script
import boto3
import json
# Change this to be the same as the region you are using
region='ap-southeast-1'
ec2 = boto3.resource('ec2',region_name=region)
cloudwatch = boto3.resource('cloudwatch',region_name=region)
client = boto3.client('ec2',region_name=region)
def change_subnet_routetable(subnetID,rtID):
  response = client.describe_route_tables(
      Filters=[{'Name': 'association.subnet-id','Values': [subnetID]}]
  rtaID=response['RouteTables'][0]['Associations'][0]['RouteTableAssociationId']
  ec2.RouteTableAssociation(rtaID).replace_subnet(RouteTableId=rtID)
def lambda_handler(event, context):
  # Change this to be the instance ID of VMX-1A
  vmx1a = ec2.Instance('i-0a1afe42842357215')
  # Create detailed monitoring for vmx1a in 1 minute interval, VMX-1A-STATUS-CHECK is the name of the cloudwatch alarm config of vMX-1A
  vmx1aalarm = cloudwatch.Alarm('VMX-1A-STATUS-CHECK')
  # Change this to be the instance ID of VMX-1B - If setup no load balancing then no need check vMX-1B
  #vmx1b = ec2.Instance('i-05d0aa2e92b6bf890')
  # Create detailed monitoring for vmx1b in 1 minute interval
  #vmx1balarm = cloudwatch.Alarm('VMX-1B-STATUS-CHECK')
  if vmx1a.state['Name']=="running" and vmx1aalarm.state_value=='OK':
    print("VMX1A UP")
    # Add one of these lines for every subnet you have.  Change "rtb" to be the ID for the route table VMX-1A-UP
    # DEV private subnets
    change_subnet_routetable('subnet-0f06b39deb3a6a0bc','rtb-02c9f6a6f60bd36e4')
    change_subnet_routetable('subnet-08104babe83ad85d3','rtb-02c9f6a6f60bd36e4')
    change_subnet_routetable('subnet-00d984b9423f807db','rtb-02c9f6a6f60bd36e4')
    # DEV public subnets
    change_subnet_routetable('subnet-0783ca3c2a9a1fa87','rtb-070257ae8030b52c0')
    change_subnet_routetable('subnet-01a0bd7312b9bd17f','rtb-070257ae8030b52c0')
    change_subnet_routetable('subnet-0af94494946901b21','rtb-070257ae8030b52c0')
  else:
    print("VMX1A DOWN")
    # Add one of these lines for every subnet you have.  Change "rtb" to be the ID for the route table VMX-1A-DOWN
    change_subnet_routetable('subnet-0f06b39deb3a6a0bc','rtb-0a1c0956298d9af66')
    change_subnet_routetable('subnet-08104babe83ad85d3','rtb-0a1c0956298d9af66')
    change_subnet_routetable('subnet-00d984b9423f807db','rtb-0a1c0956298d9af66')
    change_subnet_routetable('subnet-0783ca3c2a9a1fa87','rtb-0ee718c05fe7d2f47')
    change_subnet_routetable('subnet-01a0bd7312b9bd17f','rtb-0ee718c05fe7d2f47')
    change_subnet_routetable('subnet-0af94494946901b21','rtb-0ee718c05fe7d2f47')
Not sure if this help.
