connect Meraki to ovh
Abechara
what is the best way to connect meraki mx to OVH? is there any vMX same as Azure because ovh is not licenced same as azure ?
or just a normal tunnel ipsec, and what is the best solution ?
RWelch
MX Installation Guides link offers the setup guides for the following offerings.
Unfortunately I am not familiar with OVH (sorry).
RWelch
Perhaps you can use the Give your feedback (previously Make a Wish) feature to provide Meraki feedback on requesting implementation/integration with this cloud provider.
What is OVH?
RWelch
