Solved! Go to solution.
Any standard SNMP-based monitoring of non-Meraki equipment - including Cisco Catalyst / ISRs etc should be fine, I would have thought, even after you've set up the Meraki Dashboard as an SNMP monitoring entity in Orion.
Many thanks for your quick response on this GreenMan.. It makes it clear we can monitor Catalyst and ASR/ISR after the integration with Meraki.
Do you have any document for SolarWinds integration with Meraki ?
Generically, see the SNMP Polling section - and other linked documents - here: https://documentation.meraki.com/MR/Monitoring_and_Reporting/Monitoring_the_Wireless_Network
This is non SNMP server-specific though - we have nothing specifically for SolarWinds. I would look into the documentation for your version of Orion, in conjunction with this. Other users of both on the Community may also have useful info to add.
Bear in mind, too - I think the most recent versions of Orion also support REST API, which likely provide a more sophisticated, more future-thinking means of interaction. There are numerous possibilities with this, based upon the available and ever-expanding endpoints available in the Meraki Dashboard API, which go beyond basic monitoring: https://developer.cisco.com/meraki/api-v1/ Of course, these capabilities can be utilised way beyond - and/or in addition to - Solarwinds, too.
