Cisco MX68 - dual WANs settings
Uzair
Hi, I want to configure the device for dual WANs connections for failure purposes, can some one guide me from scratch.
basically this device is currently using for tunnel purposes to our abroad device mx64. we want to clear this config, and use as above mentioned purpose only.
thanks !
2 Replies 2
It's very easy, here is it.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
It sounds like you are using AutoVPN.  Good news - there is nothing to do.  As soon as the second WAN is online, the MX64 will automatically be able to failover between them.
