Azure vMX - SD-WAN subnet NSG issue
Dantrac
Hi all,
We've been happily running a vMX (M) appliance in Azure for the last 3 months to extend our multi-site MX AutoVPN infra into the cloud - in Passthrough/VPN Concentrator mode.
Although i'm aware it's a grey area (and/or possibly not supported!) - I was looking at deploying an NSG to the SD-WAN subnet to at least block common mgmt ports (22, 3389) and port 80 etc - mainly to satisfy our compliance and security tooling.
As soon as I associated an NSG to the subnet (even prior to defining any inbound/outbound deny rules...) - i lost connectivity to/from on-premises networks - unable to even ping the internal IP of the vMX or any resources in the hub and spoke.
Is this a known issue?  Again, i'm aware that an NSG is probably not required given the nature of the VM/appliance - but then i'm also aware that people from these forums HAVE been able to apply an NSG successfully with a deny-all rule - allowing only the necessary ports inbound (443TCP, 500UDP, 4500UDP, 9350-9381UDP and 32768-61000UDP) for IPsec, AutoVPN traffic etc...Have people applied an NSG at the subnet, or the NIC...?
I've enabled VNet flow logs on the SD-WAN subnet to see if I can work out exactly what the traffic looks like flowing through the vMX - but it might take a few days to gather enough data.
Thanks.
2 Replies 2
Configure a specific port and IP address for the VMX to use.
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
Make sure you allow that UDP port in the NSG.
Dantrac
Thanks for the reply - as I mentioned in the original post - attaching an NSG without ANY rules caused the traffic to stop flowing.  I hadn't even got to the point of adding any explicit allow rules, let alone any denies!
