See the actual configuration on your devices and also compare any changes across the historical configurations that are automatically saved in the cloud.
Dashboard will highlight any configuration changes so that it's easy to spot what was changed.
![Screenshot 2024-01-24 at 11.25.57.png Screenshot 2024-01-24 at 11.25.57.png](https://community.meraki.com/t5/image/serverpage/image-id/35262iE69D6BA80EBEC0FA/image-size/large?v=v2&px=999)
It is also possible to copy the configuration or save the configuration file to your device.
Simply click on config history tab from your Switch page.
Here's a quick demo for you
