Meraki Portal issue
IanAce
Meraki Portal issue
On Meraki portal on the list of clients, clicking on the switch port number does not display the switch port config. It just displays the list of clients again.
Thanks.
2 Replies 2
I suggest you open a support case.
Try waiting 24 hours and trying again.  Weird bugs like this tend to get fixed without you having to do anything.  Otherwise, as @alemabrahao says, you'll need to open a support case.
