Outdoor Installation of an MG51E Cellular Router
BitsAndBytes
I want to install a Meraki MG51E router outdoors. Both the MG51 and MG51E are IP67 certified, so I don't see any issues with the outdoor installation. However, I can't determine if the MA-ANT-DUAL-C1 patch antennas are also suitable for outdoor installation. Has anyone encountered this use case or knows where to find this information?
javalins
They are suitable for outdoor install, all good there.
2 Replies 2
javalins
BitsAndBytes
Perfect! Thank you for this extremely quick response 😀
