More than two LTE WAN connections
Speakup11
Hi, Would it be possible to bundle more than 2 LTE WAN connections on an MX using MG41/MG51 using the SD-WAN (Auto-VPN, and dynamic path selection)?
We have a use case in Africa where there is only 3G/4G cellular available from multiple network operators. To increase the reliability and we wan't to combine 3 networks. I did notice the MG41 and MG51 do have two sim slots. I suspect however that the MX will still see 1 WAN connection?
8 Replies 8
javalins
That's correct.  The MG has 2 SIM Slots that work in Active-Backup since there is only a single Radio inside of the MG.  The MX supports a maximum of 2 active WAN Uplinks at this point in time.
Speakup11
Thanks @javalins for your swift reply. I was afraid this would be the case. A real shame. Is there no creative workaround possible? E.g. if I combine 2 MX routers?
Looking at PepLink SD-Wan solutions and even Citrix SD-Wan, they have the option of many more WAN ports.
You could have two MXs with a pair of MGs plugged into each.  If you load balanced the WANs on those and then connected each WAN port of a third MX to the LAN ports of the first pair, you could load balance across four cellular connections.
Not the cheapest option, but...
javalins
The Caveat here is that in order to have Active-Active MX, they would need to be in separate networks.  MX's within a single network work in active-backup only.
You could use something like an MX67C.  Change one of the LAN ports to a WAN port.
https://documentation.meraki.com/MX/MX_Installation_Guides/MX64_Installation_Guide#Setting_up_second...
Now plug in two MG41/MG51.  Both can be used at the same time.
The MX67C also has a SIM slot.  You can plug a SIM into this - but note this one can only be used if the first two cellular data links fail.
Now you can have three cellular data providers configured.
javalins
This would provide active-active-backup, which gets you to three.  @Speakup11  is the goal 3 Active Uplinks? Or just have a third uplink as an option? If we aren't concerned about the number of active carriers at a single point in time, either the solution above by @PhilipDAth or @cmr achieves that.
Badr-eddine
I'm curious if you were able to achieve this using only Meraki products, or did you use any third-party solution to aggregate or bond those LTE links?
Thank you!
Speakup11
We've not pursuit this further, I'm afraid. Our idea was indeed to have (at least) 3 active cellular connections bonded together and with SD-WAN AutoVPN create a tunnel to an MX in the cloud to allow for WAN optimization / dynamic routing based on performance / quality of the WAN connections.
With the wider availability of Starlink it looks like we rely less on cellular connections, so not a high prio any more.
