Meraki 51 provide wireless access to users like access point
Adeeb_Taqui
Kindly advise about what should be reply with regards to Meraki gateway MG51
  1. Does the device support wifi signal?
  2. The second SIM is for failover, can it be configured so device will use/switch to the SIM with best performance/speed?
  3. Is the MG51-e with external antenna necessary for deployment on transport trucks that travel to remote area or  is internal antenna model sufficient?
KarstenI
1) No
2) No
3) I would assume that the MG51E with the Omni Antennas (included and don't have to be ordered separately) can service this use-case better than the MG51 as the truck will likely turn directions, and the Omni works in all horizontal directions.
2 Replies 2
KarstenI
1) No
2) No
javalins
Keep in mind that the MG51 is not certified for vibration or mobile environments, mileage may vary.
