Hi, at present I´m using the MR62 with ubiquiti nsm2 like station wds and working well, until now, I´m installed the nsm2 wich use the firmware XW, older one use XM, I try same configuration, try others configurations, but the CPE connect but don´t show RX and TX only the signal. Try differents XW units with the same problem. The XM version works very well.
Any idea.
