MG21E
DOT1X-5
MG21E
I am labbing a DMVPN setup using MG21 has my ISP.
However it is giving me a private dhcp ip address. Anyway to change this to get the public ip address instead?
GreenMan
Meraki Alumni (Retired)
No...   This is from the MG21 Dashboard settings documentation:   "The MG is only supported in routed mode.  It acts as a layer 3 gateway between the subnets configured below.   Client traffic to the Internet is translated (NATed) so that its source IP becomes the uplink of the cellular gateway."
https://documentation.meraki.com/MG/MG_Wireless_WAN_Dashboard_Settings
GreenMan
DOT1X-5
or quick response.Thanks
DOT1X-5
@agreen
The configuration shows a couple ip addresses.
Public IP
x.x.x.x
GreenMan
I'm not 100% certain, but I think it likely that the cellular IP is a dynamic IP (probably an RFC1918 one) allocated by the mobile carrier to the mobile data link itself, which will then be (Carrier Grade) NATed to a general public IP, unless you order an appropriate data plan for your SIM.
