MR46/56の最大消費電力について
tkamimura4
MR46/56の最大消費電力について
現在データシートを参照すると、最大消費電力が18Wとなっています。
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR46_Datasheet#Power
以前は最大消費電力が22Wでしたが、どのような理由で変更されたかご教示ください。
また、MR46/56はPoE(15.4W)で動作しないという仕様に変更がないかも確認したいです。
1件の返信1
MerakiDave
Hello @tkamimura4 I can check into why the data sheet power consumption was updated from 22W to 18W, perhaps it was a typo, however I see in the MR56 data sheet there is still a reference to 22W in one section but 18W in another.  I will get the documentation team to address this.  Stand by and hopefully that will be corrected shortly.  I will confirm, but my guess is the MR46 is 18W maximum, and MR56 is 22W maximum since it is 8x8 compared to the MR46 which is 4x4.
However, to answer your question, you are correct, there is no change to the specification, both the MR46 and MR56 do require 802.3at PoE+ power in order to operate properly.
