Low Power on MR57 when using Catalyst 9200L-24P
PickNetAdmin
Hi!
We have a couple of the MR57 APs that we're testing in our environment. When plugged into 3560-X or 3650 PoE+ switches, it operates at 30W normally, no issues. When plugging into 9200L switches (the model we primarily use for APs), it runs in low-power mode and constantly reboots. Even with no other devices plugged in and 2 PSUs installed, it won't use more than 15.4W. I've tried allocating 30W to the port specifically, but still no luck.
Has anyone else had this issue?
2 Replies 2
On the 9200L, you have to use a command on each port like "power inline auto max", which allows it to supply up to the switch maximum power supported.
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/switches/lan/cat...
WB
Try enabling LLDP if you haven't already, we've had the odd issue negotiating power levels via CDP only
