MX Power Cable Types
sledge121
Hi Guys
It seems like a simple issue but I can't find documentation for it.  I need to order power cables for the following devices.
MX250
MX95
MX85
I know some MX require the C15 connector and others require C13.  Can you tell me which ones from the list require C15?
CptnCrnch
C15 and C13 are compatible. Does this overview help further?
6 Replies 6
CptnCrnch
Awesome, I didn't consider the C15 to be compatible with the C13 but it obviously is as the C15 just has a notch cut out.  Good spot and thanks.
The pattern will depend on your country of origin.
See the MX67 and MX68 datasheet for example (In the Accessories section) how the part number is defined.
So it would be interesting for you to check the datasheet for each model.
MA-PWR-CORD-US1x AC Power Cable, US plug
MA-PWR-CORD-EU1x AC Power Cable, EU plug
MA-PWR-CORD-UK1x AC Power Cable, UK plug
MA-PWR-CORD-AU1x AC Power Cable, AU plug
Brash
According to the datasheet, MX's take the power cable MA-PWR-CORD-US which is a C13 cable.
If I remember correctly it's only some Meraki switches that take C15 cables.
I concur - I have only seen some of the switches using a C15.
sledge121
After speaking with other internal engineers, we have some MX250 and MX450 with C15.
