Multiple APs in your environment are doing this at the same time or just one? Typically if the AP can't reach the internet it'll still serve its SSIDs and pass traffic. Would also be worth checking what you have set at your APs management interface. Is it getting DHCP or static. What is it using for DNS.
Good morning Adam, Thanks for answering. I explain: Currently we have 55 AP MR52 of which only 6 have the aforementioned behavior. The other 49 APs work correctly with the same configuration in all APs. We have LACP configured for each AP, the ports are in native vlan 1 and DHCP is labeled an administration vlan (410) Last week everyone was working, but without traffic. But this week when there was already a lot of traffic (connected clients), this behavior appeared. Those 6 APs appear in red on the board, but physically the LED is green and you can navigate, access the internet. I do not know why this happens and I appreciate the help you can give me.
Can you try cycling the port on the switch where those 6 APs are connected? That won't get to the root of the issue but could bring them back online and checking in to the dashboard so we'd have more visibility. Also worth seeing what the switch port displays. Can you ping the APs?
Are all of these AP's on the same physical switch? Are there other AP's on the same switch not having the issue?
Have you tried a factory reset on any of the problem AP's? Have you verified the LACP status of the portchannels?
