New MR57 - Not showing on Radio Settings page
Bill_W
Added a new MR57 to wireless network.  Shows as expected on the Access Points page.  The Radio Profiles tab shows "Applied to one access point" however the Overview tab does not display any devices with that profile.  All filters are off on the Overview tab.
Ryan_Miles
Ensure you either have the new AP added to a floor plan or clear the floor plan filter.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
I believe that simply adding the AP did not cause this, I would open a support case for them to investigate whether there is a problem with the page.
GIdenJoe
This error has occurred in another case a few years back.
It is definitely a dashboard error and support will be able to fix that for you.
Ryan_Miles
Ryan / Meraki SE
