Meraki Wireless point to point link maximum range
Takis_Samanis
Hello Experts,
Typically the range that can be achieved by a Meraki AP can reach up to 100m with omnidirectional antennas as per documentation
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Access_point_range_and_signal_str...
If I want to achieve a point to point wireless link with outdoor APs and directional antennas what could be the maximum range assuming there is unobstructed line-of-sight and low interference?
What should be the best band (2.4/5/6G) , antennas , MR model for such setup?
Thanks in advance
BrandonS
In theory you can go miles with directional antennas.  Example: https://rfelements.com/products/starterdish/starterdish-um-antennas/overview
Honestly, I don't think Meraki is best suited for point-to-point to links, but may work fine for you.  You can pick up a pair-of-point to point radios for about $100  USD of various brands that will just work out of the box for fairly long distances.
BrandonS
I'm with @BrandonS , Meraki is not a good solution in this space.
Takis_Samanis
Thanks a lot guys.
