Meraki SSID set to Radius prompts users every morning for Radius username/password
DaleSmithGuy
I created an SSID using Radius authentication. Every morning when users open their laptops they are prompted to enter their usernames/password again. I'm fairly sure this is the Windows Radius server but I am unable to figure out why this is happening or where.
Any assistance would be appreciated
KarstenI
You have to push a WLAN config to the devices, for example by GPOs. There you can set the authentication to use SSO with the Windows Login. Based on the Windows version you perhaps have to disable Credential Guard in Windows.
Is this in Active Directory or Radius?
GPOs are configured from the DomainController.
Gotcha
