ESL in template
MX
ESL in template
Hi!
you can read a alot in this document ragarding ESL:
https://documentation.meraki.com/MR/Deployment_Guides/SES-imagotag_Electronic_Shelf_Labels_(ESL)_Int...
If we want to activate ESL in an template with mixed AP supported(mr44) and no supported(mr42). Can you activate ESL anyway?
Will ble beacon function deactivate on all ap in that template or particular ap that you really activate ESL on?
MS
MX
Good to know @AlexanderN . Then a try to reach support again, to activate that on our templates.(last time the didnt know that)
MS
@MX.,
The documentation say that It will be deactivated just on access points that you are enabling ESL.
AlexanderN
Meraki Employee All-Star
Hi @MX ,
SES ESL integration is a per-AP feature. If you use a template, ESL needs to be enabled on a template level, and a V:Cloud URL needs to be set (assuming that you are using the direct connection to V:Cloud). Then,  ESL functionality must be activated on individual APs within each child network.
There is no impact on BLE functionality for APs that don't have ESL enabled unless you explicitly turn off BLE on the template level.
MX
MS
