Hi @Limitless
I am sorry for your experience. Just to get some clarity over this issue, Did you able to open a case with Cisco Meraki support regarding this issue and received no response except the case closure? Can you please follow up on the case and re-open it? (You can do this by simply replying to the email you received from support). This might have happened by mistake, generally, our support team is very responsive and communicative. Also, please feel free to give the support team a call to discuss further (You can find the support hotline number on the dashboard under help > get help)
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
