Best way to troubleshoot Wi-Fi dropouts?
Craig10
We are experiencing Wi-Fi dropouts randomly without any pattern.
This issue has been confirmed just Wi-Fi and noticed particularly on Teams calls (we use Teams a lot though!)
Looking through Meraki portal logs, I am unable to see any obvious issues.
Can anyone provide me with advice to progress this issue?
TIA
11 Replies 11
Did you notice this issue in a particular device type (android, Windows, IOS, Etc.) or all devices? What type of authentication are you using? Are 802.11r and 802.11w enabled?
Take a look on this documentation:
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices
Tintin
How does it look at the ”Event log” tab for the the access points?
I'm also having trouble with dropouts for various devices and in the event log I (among other things) see:
That info ”i” to the right of the messages doesn't give any info when clicked or hovered over. 😞
Another log entry for a devices says: 802.11 disassociation – disassociated due to 802.1X failure
I see there are other threads about ”802.11 disassociation” problems, but no clear answer on what to do about it. I guess it's complicated. 😄
Edit:
Maybe this thread could be on to something:
https://community.meraki.com/t5/Wireless-LAN/802-11-disassociation-issues/m-p/76859
We have a lot of disasociation - unknown over a small period of time-this screenshot is over the last few minutes
Is this normal?
Craig10
Mainly Windows & IOS. 802.1X with custom RADIUS.
Are there any links on that documentation that may be particular to my issue?
Craig10
Not sure, where do I find that out?
On SSID configuration.
I suggest you to take a look on these documentations:
It's not just install access points, and It will work like magical, you have to follow some best practices.
Craig10
Both disabled. Do I need to enable either of them?
Nope, well, there are many reasons that could be causing this issue. How many access points do you have in your infrastructure? Have you performed a site survey? It's normal to have dissociation when clients doing roaming.
So I suggest two things:
First read the documentation.
Second, try to update client's driver Wi-Fi.
In time, What firmware version are you running?
