Active directory Integration (MR-42)
William-PE
Dear,
Good morning, I am trying to integrate my meraki solution (MR-42) with our active directory so that our Wi-Fi clients can inherit the group policies. And they can match our firewall (FSSO)
Currently I have set the fields of the SSID as indicated by some documents however I get the following error:
It is worth mentioning that the username and password of the admin are correct.
If I was skipping a step, indicate which one is
Thank you very much.
Regards
Will
1 Reply 1
