Access Points Contacted At Not Working
JPaul
Hi
Anyone else seen where all devices going through an MPLS via Firewall have stopped showing as being Contacted and stop updating their configuration.
All Firewall rules as per dashboard are correct
5 Replies 5
Adam
Just the access points?  Setup a port on the switch the same as the AP and try attaching a computer to test/verify to ensure there isn't connectivity issues.  If you cycle one of the APs does it come back online?
JPaul
No any Meraki device that goes through our firewall
anythingbon broadband has no issues.
Adam
From the dashboard go to Help>Firewall Info
You'll need to verify those things aren't being blocked somewhere between your devices and the internet.  Likely your edge firewall or MPLS network.
JPaul
appreciative that Been checked by Meraki and Data centre and both confirm all ports are allowed
Was firewall
