[ASK] mac filter with PSK
luthfigibrani
Hi..
I want to know, is it possible to filter specified mac-address can join ssid with PSK Authentication?
In the dash board only MAC-based access control (no encryption) with radius.
Thanks and Regards,
Gibs
9 Replies 9
luthfigibrani
I mean, we assign mac-address list manually on the dashboard not using radius
Unfortunately, the only way is using a Radius server.
KarstenI
The best way is to do it with a radius-server. There you can define which MAC-addresses are allowed and also pass the correct passphrase for encryption to the AP. This is done with "iPSK with RADIUS".
luthfigibrani
What about white-listing mac-address on client menu per ssid? As image attached:
 is there any trick to make it happen?
I think it is not what you want. When you put the client in an allow list it will apply the following settings to a client:
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Block_Listing_and_All...
It is not a trick, it just won't do what you were asking for as the PC could still join the SSID.
If the workflow is ok for you it can be implemented this way:
  • Default policy is to block everything (or perhaps allow DHCP)
  • the client connects to the SSID
  • the client gets whitelisted on the dashboard by applying the right policy
luthfigibrani
So every client still can associate with the ssid, since the firewall rule is deny all. Only the white-listed client could use the ssid for communication. Is that right?
In other words, white-listing is a way to bypass any firewall/policy rule, isnt it?
yep
