Has anyone tried to configure SSID visiblity (ie whether the SSID is hidden or not) using APIs ? When creating a SSID via API you can't control its visibility and there is not other API endpoint that seem to do the job.
That would definitely be a good candidate for a make a wish but I prefer to check if I'm not missing something first!
Thanks.
