1. When placing APs on the map (standard google map setup) does their placement on the dashboard map affect their actual performance and radio management or is that just for us to view their approximate location?
2. Is there a way to upload floor plans and have them match the orientation of the maps? I can't seem to get it working right.
No, the placement on the dashboard should have no effect on actual performance. It’s just to create a visual. Also, when you’re using a floor plan, you can adjust the size to fit whatever you need. Just use the circle/square to adjust.
Thanks for that. I'm now seeing an issue where I see the APs, or I see the floor plan. It's like the APs are hiding under the floor plan. Is there a way to move them to the top or move the floor plan down a level?
