Meraki Cameras connected to Non Meraki Switches
degarris
Our customer will have us install and configure hundreds of MV72 cameras to what appears to be a variety of non Meraki switches, unfortunately don't have the vendors names yet, we do know they support POE, are there any known issues with this or helpful tips ?
BlakeRichardson
@degarris  As long as they can provide the required POE wattage then you shouldn't have any issues.
For non POE switches Meraki sells 802.3at PoE Injectors
BlakeRichardson
Thank you
EJN
I have 102 MV cameras installed. They are all connected to non Meraki switches. Most are Brocade (Ruckus) POE switches, some are TP Link POE switches, and some are unmanaged Netgear POE switches. Never an issue with compatibility.
If you have non POE switches, you can use POE injectors as previously mentioned. Depending on your environment and budget, you may want to invest in POE switches.
Esteban J Nunez
School and Church
K-12 Education
Appreciate the information, this gives us confidence as we move forward with the installs.
