vMX Installation
NewMerakiGuy
vMX Installation
Hello, I'm trying to install Meraki vMX in the AWS and I got the license. I built the vMX instance in the AWS and claimed the order number in the Meraki dashboard and I can see the license has been added.
My question is, I tried to add new Network, but there is no vMX security device available to add to the new Network.
Please can someone guide me how to do this ?
Create the network as type Security Appliance and not the default which is Combined.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
5 Replies 5
Refer the documentation.
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Amazon_Web_Services_(...
NewMerakiGuy
I'm following that guide, but the issue is I don't see the "Add vMX" option when I'm creating new Network. Any idea ?
Which Network Type are you using?
Ryan / Meraki SE
NewMerakiGuy
The Dashboard was not showing that option yesterday, but today works for me. Thanks!
