Two MX questions
mike318
Two MX questions
Why can't I sync blocked URLs amongst all my MX products (8) in my Org?
Why can't I submit URLs to Cisco for AMP consideration? Surely user submitted URLs would boost effectiveness.
jdsilva
You can block url's on all MX's if you're using templates...  I know, not likely the answer you're looking for but it's the only way currently to do that. Org level policies would be really nice for quite a few things with regards to MX's (I'm looking at you SD-WAN).
URL filtering is Brightcloud based. You can submit requests through them. Info is here:
https://documentation.meraki.com/MX-Z/Content_Filtering_and_Threat_Protection/Content_Filtering/Cont...
5 Replies 5
jdsilva
Adam
I agree @mike318 it has been on my wishlist for a while to have a shared blocklist/whitelist for an entire org.  I still like being able to individually set a blocked or whitelisted item but would be nice to have one master one as well rather than having to go through and manually add it to my 20 different networks.
Edit:  We now mostly use OpenDNS Umbrella to do centralized blocking through our org.
MRCUR
@Adam Not to go too off topic here, but how do you like Umbrella? Is there any real integration with the MX/Dashboard yet, or is administration still completely done in the OpenDNS UI? Any big gothchya's with it?
MRCUR | CMNO #12
mike318
I would also love more info on this. thanks
Adam
PM'd @MRCUR we can start an offtopic thread if desired.
