Question on VPN Exclusion with SD-WAN + license
ToryDav
When using an MX as a branch spoke connecting to a concentrator in the data center, we need to implement a full-tunnel design to send all wired traffic on the network through the Corperate firewalls located in the data center.
However, I also have a requirement to send the local office wifi traffic (both office user and guest) out to the internet directly at the spoke level.
When I choose to send the default route to a spoke MX creating a full tunnel, am I correct that I then need an SDWAN + license to enable Local Breakout for a couple of wifi vlans to not use the default route through the tunnel?
Brash
All MX licenses support local Internet breakout based on port/IP
https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
Only layer 7 (application) based local Internet breakout requires the sd-wan plus license
Brash
You could use source based default route for this. (In case you dont advertise the default route in the vpn globaly)
https://documentation.meraki.com/MX/Networks_and_Routing/Source_Based_Default_Routing
RaphaelL
Wouldn't selecting these vlans and put them 'vpn off' already solve that issue ?
