Non meraki vpn
Fdelchiaro
Non meraki vpn
Hello, how can I set up a workaround in order to make a non-meraki vpn working with a peer having a redundant connectivity? Example: if the external site switch the connectivity I have to manually correct IP every time.
Is it possible to set multiple IP addresses?
Thank you very much
2 Replies 2
Jwiley78
The most familiarity I have is with the Cisco ASA and as far as I know that is not possible.  This is due to the config being hard coded to Public IP.
It's not straight forward.  You have to use tag-based failover.
https://documentation.meraki.com/MX/Site-to-site_VPN/Tag-Based_IPsec_VPN_Failover
